iBook G3 Clamshell LCD display replacement (LTN121X1), help!
I need some help in setting up new screen for iBook G3 clamshell.
I replaced the LCD screen according to this nice instruction in https://ibookmod.livejournal.com/559.htm.... I used model number LTN121X1-L02 LCD screen from Aliexpress.
However, I got the screen attached and I guess this is normal. I should change the setting to see the proper display.
Then, I found this site but just pictures were shown with no explanation (attached).
https://www.flickr.com/photos/46722368@N...
Can you help how I can modify the setting to see the proper screen?
Thank you so much in advance.
Это хороший вопрос?
Счет 0
1 Комментарий:
@dawnpa we need to see what your "setup" looks like. Post some good images of your "conversion", including the connection etc. with your QUESTION. Adding images to an existing question
из
Добавить комментарий
