How to place the mouse battery spring terminal properly
Mouse broke apart and I'm trying to slot in the battery spring properly to no avail
Это хороший вопрос?
Это хороший вопрос?
Hi
If the spring is on one side of a compartment do the opposite on the other compartment
It would be diagonally across when correct
In terms of how it should be wired it should be wired + to -
It should have a positive and a negative on the board
Hopefully this helps
Any questions please ask
Был ли этот ответ полезен?
За последние 24 час(ов): 1
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 60
1 Комментарий
@j1nju that is the negative contact. Post a clear image of the negative side of your battery space,so we can see what you see. We need to see the other side and a bit better lighting :-)
из oldturkey03
