My pc is also power cycling, Any help or tips?
My pc is also power cycling, I took everything apart and placed it back together and it still does it. Any help or tips?
Update (02/26/2023)
Motherboard: AMD ASRockB450MPro4
PSU: ROSEWILL ARC550 80+ bronze
CPU: ryzen 7 5700G
GPU: Nvidia geforce gtx 1650
RAM: 2x 8gb DDR4 3600
I turn It on and everything lights up but get a black screen for around 30 seconds, then it turns off and immediately starts up by itself again, then repeats the process
No its not brand new
Это хороший вопрос?
Mine is also doing the same thing and on top of which I put. when I push the power button it wouldn't Start all in all. it was doing was sitting for about a month or two, unused. So I had to bypass the start switch and jump the wires to get it to try to start and then it power cycle. I'm thinking it might be the CMOS battery Keeping it from running post? I'm going to try that route today and see if that fixes it. If so, I'll post back up on here the results.
из Jerry Beaugez III (Beau)
