The Samsung Galaxy A10 is an android smartphone developed by Samsung Electronics. It was released in March 2019.
Why is wifi not working
When i switch on wifi, it does not show available routers & it does not access any wifi connection
Это хороший вопрос?
Счет 0
2 Комментариев
WiFi not work
=== Update (05/11/24) ===
Samsung A10 WiFi not work
из
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi,
Try using the phone's WiFi as close as possible to your network router i.e. <10cm and check if it detects the networks and connects to it.
If it does then it may be a loose antenna problem.
Here's an image of the phone taken from a teardown video that shows the antenna connections at both ends of the phone.
(click on image)
If it still doesn't work it may be a problem on the systemboard. Here's an image of the no BT/WiFi troubleshooting flowchart that may help.
(click on image)
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Kano Leatile буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 22
За всё время: 514
