Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
429вопросов Показать все
iMac mid 2011 21.5, what is the gap for thermal pads on vram?
I got the dreaded stripes and tried the baking method and amazingly it worked. But it came back and I think it's because I used regular thermal paste on my vram instead of pads or thick paste.
I'm going to get the pads but looked everywhere and can't find if I need 1mm, 1.5mm, or 2mm.
Thanks!
Это хороший вопрос?
Оценка 0
1 Комментарий
**Update**
I got the K4 and K5 paste and redid the whole thing properly. Unfortunately I still have the stripes.
**Question**
I wonder if I actually zapped the gpu.
**What happened**
On that first attempt it worked fine and I only booted it up and observed but after a short while (less than 1 hour) the stripes came back. I know I didn't apply enough paste (which was confirmed when I took it out).
On my second attempt I re-baked it, applied the proper amount of K4 to gpu and K5 to vram and still got the stripes.
**Next Steps**
1) Buy a used card and try a third time (I assume the risk is that a used card is also fried).
2) Re-bake my card again
3) Take it to Apple and expect them to charge me hundreds which I'm unwilling to pay for a 2011. But maybe it'll be less.
Any wisdom y'all have is appreciated!
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
This is what I’ve used Minus Pad Extreme
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
thanks. from their site it says, "The minus pad extreme is available in size 120 x 20 mm and 100 x 100 mm with thicknesses of 0,5mm, 1mm, 1,5mm, 2mm, 3mm."
which size did you use?
из
@justin06pdx - I always dry fit and either use a gap gage or some strips of card stock to fill the space to gage the size needed. I mostly find this series uses a 1.0 or 1.5 depending on the board used.
из
Gotcha. Mine was the AMD Radeon HD 6750M (or 6770M) with 4 vram chips.
Trying to figure out which pad to get sent me down a long rabbit hole so I just ordered the K4/K5 Pro thermal paste that is used to replace gaps. Apparently it's not great for high end stuff but I'm on a 12 year old iMac used for basic office stuff so hoping it works fine as many reports say it does.
https://www.newegg.com/p/2MB-0028-00002
из
Добавьте свой ответ
Justin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 66
