This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
Bottom screen flash no boot
The top screen is previously been broken and open up the device to try and clean out and re-insert the ribbon cable and then I got the black cable stuck under the game card slot and when I close the consul and boot it up it wouldn’t work help please
Это хороший вопрос?
Счет 0
1 Комментарий
This Nintendo DS was purchased at a St. Vincent de Paul for around $15 and I don’t wanna give up on it. It has a broken game cards not L trigger but the motherboard otherwise works.
из
Добавить комментарий
1 ответ
Выбранное решение
Look's like your top screen ribbon cable has an issue, i had the same problem with three DS's , you need too replace the top screen, unluckily there's no other solution
Nintendo DS Lite Upper LCD Replacement
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
hello, I got rid of this Nintendo DS a very long time ago since this question was asked 10 months ago thanks for replying and giving me an answer and since I have more experience, I’ve been able to learn about this more but the DS had bent pins bad trigger broken hinge, so that’s why I got rid of it but anyways thank you.
из
Добавьте свой ответ
Sqwerks буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 114
