Keeps shutting down when charging/ syncing
My iPod keeps resetting itself when I charge or try to sync it Now I can't back up my iPod as it shuts down in the middle and then reboots itself also I can't have any new stuff on it coz within few minutes of connecting it to power supply source or USB port it shuts down and restarts
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
It sounds like the battery life is at it's end. Try replacing the battery!
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
Thanks for your answer. But if I leave it on charge for a while it gets charged and lasts me good amount of time, is it still battery issue?
из
It could have a bad power control circuit problem on the battery pack itself, or a loose or bad solder connection on the logic board .
из
You may want to check and see if a ribbon cable may have came loose.
из
Добавьте свой ответ
Nav буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 603
