m5884 dc internal broken -- how to change it
hallo... i've to change the dc connector...+ pole broken
is possible to have a guide... it is different from newer model...
i've the ac connector covered by a floor of circuit....
It's my first mac (bought in 2000) ... i would to my daughter the opportunity to play a little bit with him ...
I'm writing from switzerland and now i have my second mac... a MacBook Pro model 2009 .....
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Ifixit doesn't have the manual for this repair, but if you look here: PowerBook G4 Titanium Mercury you'll see various other rapairs that will lead you in the right direction. This repair PowerBook G4 Titanium Mercury Logic Board Replacement will most likely suit your needs.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
thank you from Switzerland ....
i'll check ....
из
No Problem. Good Luck.
из
Добавьте свой ответ
fausto будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,773
