Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
44вопросов Показать все
Both cameras stopped working after battery replacement
First of all, I'm new to repairing electronics so bear with me :)
After changing the battery both cameras no longer work. First thought is that I accidentally broke something during the repair, but I'm a little puzzled as to why both cameras are malfunctioning. I'm figuring the problem might lie somewhere else than the actual cameras.
Can anyone help me identify what could cause this issue?
Это хороший вопрос?
Оценка 0
1 Комментарий
So I changed the rear Camera and both cameras worked after that
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Glad you attempted your own repair! Start by checking the connectors for both cameras. Always make sure to disconnect the battery. Its best to slide the guitar pick next to the battery connector, not directly under it as you can bend or damage the pins. Make sure they're free of debris and foreign objects. Also make sure they're not damaged or missing any pins. Once that is done make sure the connectors have a firm connection. They should snap into place like Legos. After you've confirmed they have a firm connection, you can test the device without fully assembling it. Just make sure you touch the glass and not the actual LCD to interface with the device. The digitizer is in the glass, not the LCD itself.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Lars Pugh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 33
