hisense on screen then no display
tv comes on shows hisense on screen then no display standby light still on
s off
Это хороший вопрос?
s off
Это хороший вопрос?
@andrewallner you are not giving us much to work with here. Let us know what model your TV is and what you have checked and what you have tried to fix this. The very first thing to check, regardless of model, would be your backlight. Hisense is not known for quality parts.
The very first thing to do , is to verify that you have no image on all inputs. If it remains dark, unplug it and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, use a flashlight and angle it against the screen with the TV at a station where you can hear the sound See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back. then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in to make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
Now , depending on the model, there may also be some firmware issues that prevent your TV from moving past the POST splash screen (that is where the Hisense appears)
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 16
