Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
77вопросов Показать все
The System cannot be restored on this device. Failed to restore device
Failed to restore device in recovery mode, libusbrestore error: 2012 [com.apple. MobileDevice. MobileRestore
- Ox7DC (2012)|
Это хороший вопрос?
Оценка 1
1 Комментарий:
Hi! Have you sucseeded solving the problem? I've spent couple of days trying to fix MacBook Pro 2018, it got worse and worse, no options, same Ox7DC (2012) DFU error.
из
Добавить комментарий
1 ответ
You need to fully wipe the drive, but to do that you need to boot from an external drive to then run Disk Utility from that externals files.
You have a bit of a Towers of Hanoi problem
You need access to a second Mac otherwise or if the internet recovery is working you can build the external drive but Apple doesn’t make it easy! As the recovery will be the original macOS not what you are running today.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
I have tried restoring with 2nd Mac Book. But that’s the message, which keeps popping up. Any other methods.?
из
@yayavat48 - Did you do a full reformat of the drive and only install a fresh OS from the Apple OS installer?
из
Добавьте свой ответ
yayavat48 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 65
За всё время: 1,673
