What could cause slow movement through apps and lines through screen?
Tv was not displaying before but after replacing tcon board and main board i get some picture but still getting this
Это хороший вопрос?
Это хороший вопрос?
@sebas99047 try all different source inputs. This looks like a issue with the LCD driver boards on your panel. If you still have tohe back open, post some images of the boards where the cables from the T-con board terminate. Those are hard to reach on some of the TV's. Also, you could try new ribbon cables from the main board to the T-con board and T-con to Driver boards. Commonly, if your VON/VGH voltage is missing, your TV will display in slow motion.
You need to EDIT your question to add additional pictures Adding images to an existing question
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 46
