A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
How is the lcd backlight powered
I'm trying to repair my Touchpad from a water spill. The digitizer and lcd seem ok and are responsive. The screen doesn't light however. Does anyone know where the backlight is powered from (maybe lcd cable or some other contact on the board) or if it can be replaced if needs be?
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
i'm afraid that the backlight power is on the same wire with the screen. So if there is a problem with the backlight means that you have to change your screen to fix it.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Mark Turner буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 902
