Blackscreen with blue dots when booting - RESOLVED
So this morning i turned my pc and worked perfectly but then my pc got so loud for some reason my screen turned black and then i turned my pc off by pressing the boot button on my pc after this i get a Blackscreen with blue dots.
Это хороший вопрос?
7 Комментариев
I did happen before but worked fine once i restarted
из RedMoka
Secure bios was off if that helps
из RedMoka
Hi @redmoka65383,
What is the make and model number of the motherboard and GPU card?
Can you try another monitor (TV perhaps if GPU has HDMI output) and check if the same problem occurs?
из jayeff
Motherboard- Nzxt N7 B550 amd
CPU - Ryzen 7 3800x
I will try on my tv and i do not know the model numbers
из RedMoka
Bios work perfectly
из RedMoka
Показать 2 больше комментариев
