Water Repair Bold 9700
How I Can Repair A Water Damage?
Это хороший вопрос?
Guillermo Eirin, I would start by disassembling the phone and cleaning it. Use this as a general guide. You can find a teardown for your phone right here. There is also a take apart guide on here. . Hope this helps, good luck.
Был ли этот ответ полезен?
Shake and wipe water off , open phone and wipe parts (try with a non static cloth ) put phone in a bowl of rice for a couple of minutes(30) that will take out extra water if next day it does not come on get a new battery and see if problem continue if it does get a new phone .
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 2,119
1 Комментарий
most likely you will need a new battery, once you have cleaned the phone I'd buy a new battery and then see what if anything works, get back to us.
из pollytintop
