The Motorola Droid 2 (A955) is the fifth phone in Verizon's Droid line.
13вопросов Показать все
T. 5.5 Torx striped
I ordered your large fixit kit with all the torx and such but when following exact directions in removing the 5.5 Torx screws from this droid 2 (Global) they started to strip the 5 is way to small to start I went to a 6 torx and was able to remove three.. Any hints to remove these other stripped screws? I am about to just drill them out.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Check out the answer here for some suggestions on stripped screw removal. If you go the route of power tools just be sure to be careful and steady so you don't damage any surrounding components. Good luck and I hope this helps.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
John McGrath будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 892
