Blue light stays on, no screen causes and troubleshooting
Hello i recently bought this new 3ds with a known blue light stays on, no screen output issue. After taking it apart i have several questions regarding troubleshooting and parts to inspect. I find that the documentation for troubleshooting the new 3ds non XL is almost non existant. I've found several issues:
- The microphone cable is torn
- A cable appears loose in a to me unknown connector
- The SD card slot screw is stripped
- The top screen connector seems to have a bent pin
What I am wondering is:
- If the microphone is needed for the console to turn on or if I can ignore it.
- What is the function of the loose looking cable and does its connector have a name so I can find out how to open the connector and reseat the cable
- If there are any good ways to remove tiny stripped screws (tried most common household tricks rubberband, other bits) or if it is looking doomed where I can find the plastic housing for the SD card so I can destroy the current one and buy a new one. I've tried googling and checking Aliexpress to no avail.
- Could this bent pin be responsible for the top ribbon not making full contact and the console not starting because of it?
- If none of these what are the most common reasons for blue light no screen (ps i have tried reseating the wifi cable)
The issue with my new 3DS console is that most online resources are tailored to other variants of the 3DS lineup. So, I'm feeling lost and can't seem to find others with the same problem with this specific console.
Это хороший вопрос?
2 Комментариев
Tried bending the pin from 4.
It snapped instead of bending
из unitop
Hi!
I posted an anwser but it doesn't seem to show up, so here's the short version: the ribbon on picture 4 isn't the top LCD ribbon but the camera ribbon. Try disconnecting it and booting your console, it isn't needed to boot but it can cause black screen issues if there's something wrong with it.
из K. S.
