Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2193вопросов Показать все
Вопрос закрыт
Unable to obtain Verizon 3G signal
I have a Verizon iPhone 4s that cannot receive a 3G signal. I do see the bars, the Verizon wording, and roaming "O" symbol. I am pretty confident the area I live is has a good signal.
Problem occurred after I replaced the digitizer. I made sure everything was connected and in place prior to powering it up.
I verified the pressure contact was cleaned prior to installing it. I also swapped out a pressure contact from a functional iPhone. Still wasn't able to pick up a 3G signal.
Can anyone advise on next steps to troubleshoot? E.g. Reset all settings perhaps? Upgrade iOs?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
You might want to try this:
1. Save everything on your phone not through a backup (Write a list of apps, sync notes, contacts, etc. through iCould and save photos/videos on your computer)
2. Restore with the latest software
3. Put everything on the iPhone, not from a backup (download apps, setup iCloud, and put the photos/videos on the phone.
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 839
