What is wrong with iPod touch screen?
I have been looking everywhere for the answer to this problem but have found nothing! I have a used 3rd gen ipod touch. The first day that I had it, it worked fine. I knew it has some problems but I was shocked that it it ran perfectly the first day. I turned it on the next day and it was ok for about a minute before the screen started acting up. Things got blurry, there were lines all over and they seemed to move and flash. You could make out the screen behind but eventually the lines over came it all and it was noting but white lines making it impossible to see anything. However, the touch screen still worked and you could still hear the music. This leads me to believe that it might be the lcd screen. Has anyone else had this problem? What did you do?
Это хороший вопрос?
Счет -1
1 Комментарий
what problems???
из
Добавить комментарий
1 ответ
Выбранное решение
From the description of your symptoms it sounds like the LCD itself is the failure point. In between the layers of glass, masks, liquid-crystals and more glass is a grid of transparent conductors. three for every row, RGB, or Red Green and Blue the component colors of light. On the opposite side of the liquid crystals is another grid, but with only one conductor for all three, this is known as the common line. The displays circuitry places a voltage across the front three changing the color of the pixel and the minute current is returned via the common. Now if the common line fails, an entire column, or row of pixels fails in the full open position, giving you that white line.
The iPod itself has no idea this is happening, it is just commanding the display and listening to the touch screen. This is why you can still control it, but can not see the interface. If you can connect a set of AV cables and get un-corrupted video you have even more proof that the display is at fault.
Consider replacing the display using the guide found right here on the iFixit site iPod Touch 3rd Generation Display Replacement
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
Jessie буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 3,319
