The screen is flickering and how to solve this
what is the cause of this and how to fix it. the startup and everything else is fine.
Это хороший вопрос?
Это хороший вопрос?
Hi @zainurizzat
Connect an external monitor (TV?) to the laptop's HDMI port and check what the display is like on it. Press the Fn+ F5 keys (both together) to toggle between the laptop display only, the external display only or both on together.
If the external display is OK there may be a problem with the video cable connection (loose?) between the motherboard and the display panel or more likely a problem with the laptop's display panel. Has the laptop been dropped or gotten wet at all?
Here's a video that shows how to replace the display panel in your laptop, that may help.
Был ли этот ответ полезен?
За последние 24 час(ов): 1
За последние 7 дней: 5
За последние 30 дней: 19
За всё время: 1,046
