Repair and disassembly guides for HP printers.
1196вопросов Показать все
My printer started printing only pink colour
My printer started printing in pink only. all the ink cartridges are more than 50% full. I have done all the diagnostics, cleaning and no fix
Это хороший вопрос?
Оценка 0
2 Комментариев:
Hi @thandimhlambiso,
What is the model number of the printer?
Does it do this if you copy/scan a page using the printer's control panel as well as if you print from a computer?
из
My printer is a HP Smart Tank 615. Everything functions on the printer as normal. copy, scan, print etc. The ink tanks are between 50%-80% full. The only issue is that everything I print with the normal colour settings, it prints in the colour pink. From any and all applications. Although if I choose to print in black-only, in the printer system settings, it will do so.
из
Добавить комментарий
1 ответ
While these essentially use modified tri-color carts as "printheads", the carts aren't as readily available as Canon's modified tri-color design (they cost something like ~$20 with Canon). However, this does mean cleaning these things is viable and relatively easy. If you can remove the "printhead" and not make a mess, soaking the color "printhead" often fixes this issue. If you can't clean it, I did find it for $23 from Encompass.
The Epson ET series is a disaster when this occurs; you need to take half the printer apart, remove the "ink carriers", put something like a blue shop cloth under the printhead, rub the head with cleaner (to get rid of any dry ink on the head plate) and push cleaner through and then run a light cleaning cycle to get ink back in the head if you don't want to burn your waste ink pad up on the "sealed" ET models or replace a $20 consumable item. These have the disadvantage with photo printing due to the limits of CMYK vs CMYK+GY or CMYK+LC/LM or even Ultrachrome 10 (CMYK+PK/VM/LC/VLM/GY/LG/Violet) but it doesn't matter for home users, honestly; being able to service it is probably a bigger feature.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
thandi Mhlambiso будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 14
За всё время: 57
