Blinking orange light laptop
Can I ask a question everytime I plug my laptop it's always blinking and not powering on pls help
Это хороший вопрос?
Это хороший вопрос?
A blinking amber battery charging indicator means that the AC adapter is connected but the rechargeable battery cannot be charged as the battery is too hot or too cold for charging. The charging process is continued as soon as the rechargeable battery has reached a permissible temperature again.
Assuming that the ambient temperature around the laptop is OK perhaps the battery is failing (faulty?) and needs to be replaced.
Here's a link that shows how to remove the battery pack from the laptop.
Search online for Fujitsu Lifebook E546 battery to find suppliers that suit you best.
Был ли этот ответ полезен?
I removed the battery and now it's blinking blue
it's probably not designed to work without the battery inserted.
You may have to check what the battery voltage is on the battery itself or replace the battery.
Even rechargeable batteries have a lifespan
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 53
За всё время: 619
