Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
Вопросов 17 Показать все
Charger and power indicator.
My laptop is critical low battery. When I plug in the charger the charging indicator will blink 3× times then power indicator which is blue blink and then they blink at the same time. What is the possible problem and the solution. Thanks for the answer.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
I have the same issue in the laptop. Mine is because I've used the charging port badly. It will probably need a change of the port.
Also, my fans turn up and down without any reason, and doesn't for a while when a game is being played- get's heated until I turn fans to max in NitroSense.
I don't know if that's related to the charging issue though.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
MASHEEET будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 99
