Released in January of 2021. Identified by model numbers SM-G996B, SM-G996B/DS, SM-G996U, SM-G996U1, SM-G996W, SM-G996N and SM-G9960.
24вопросов Показать все
Loss of cellular data with new power charger daughter board
My charging port was not working so I changed out the daughter board. New board charges great, but cellular data no longer works. If I put the old one back in it works again. I have tried 3 different replacements with same result.
Это хороший вопрос?
Оценка 0
1 Комментарий:
Where are you buying the new boards from and are they genuine samsung? Also make sure you are buying the correct board for the model number, not just s21+. Look for SM- etc.
из
Добавить комментарий
1 ответ
What @strongbow said above. Make sure you're using the one that corresponds with your model. There's an international and US version of the daughter board. If you use the incorrect one it can result in a no service issue. Order an OEM one if you can.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Doug A будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 23
