2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Replaced left speaker but now screen is black
I replaced the left speaker in my MacBook Pro and had to remove the motherboard in order to do that. After finishing and putting computer back together, when I turned on the computer my screen is black but I can hear the startup sound
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Using a flashlight shine it into the lids Apple logo (a poor man’s backlight), do you see a faint image of your desktop and its icons?
Был ли этот ответ полезен?
Оценка 1
6 Комментариев:
No, I unfortunately see nothing when doing that.
из
@michaelaspeaks - So the video signal is not reaching the display then. Check the displays LVDS cable and the logic board connector for damage.
из
I think you’re right, it might be the lvds cable. It looks like two prongs got bent when I initially put it back together.
из
@mspeaks57 - These are easy to damage. Now you have to replace the cable which will require taking off the display and replacing the cable MacBook Pro Retina (2012-2015) Display LVDS Cable follow this guide MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement focus on Step 4 in this MacBook Pro Retina Display Teardown you only need to get to the connector on the T-CON board.
из
Thank you! Just need to get the cable now
из
Показать 1 больше комментариев
Добавьте свой ответ
Mspeaks57 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 107
