The Lenovo Yoga 920-13IKB is a two-in-one laptop that functions as both a laptop and tablet by flipping the screen around.
Computer Will not turn on or charge
Out of the blue, my laptop died. It won't charge. Charge light won't come on and it won't power up and turn on when the power button is pressed. I don't get it, as I hardly ever used this computer. I've heard the computer has some firmware issues reading online. But I tried all the recommended hard reset options, including detaching the battery cable. But no dice. Is my mother board dead? If so, how can I make sure? Thank you.
Это хороший вопрос?
Оценка 2
Добавить комментарий
Ответов (2)
Выбранное решение
Hi @hatelenovoyoga,
Have you tried using a different, known working compatible charger to see if the laptop started to charge when it is connected, you didn't say?
Try using a strong light and a magnifying glass to visually inspect the USB-C charge port pin connectors (where the charger plugs in) to make sure that they're all there and not that some may be bent, broken or even missing.
Here's a link that describes the USB-C pin functions that may help.
If there are missing, bent pins etc then the charge port (supplier example only) will have to be replaced. You will need smd soldering skills and tools to do the repair. Here's the hardware maintenance manual that may also help as the systemboard will have to be removed so that the port can be replaced. The manual details how to do this.
If the charge port appears to be OK, here's a link to the schematic for the systemboard (if your model is an NM-B291 REV:1.0 that is). Go to p.41 to view the connections for the charge port so that you can check if power is getting through the port OK and how far into the board it gets etc.
Hopefully a start.
Был ли этот ответ полезен?
Оценка 1
Here are some quick fixes for this issue
  1. Try changing your laptop charger
# If charging point is blinking and caps lock is blinking then you need to repair the motherboard of the laptop,
Оценка 0
Добавьте свой ответ
HateLenovoYoga будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 7
За последние 30 дней: 36
За всё время: 541
