My old pc was running fine until it suddenly turned off
Hi I have an old computer
Today I turned it on and it worked fine for ten minutes until I opened YouTube on a browser and right about when it was ready to load the computer suddenly turned off.The pc wasn't turning on again.I changed the power supply and the pc turned on but the pc turned on when I pressed the power supply's button(Which is strange because It should turn on when I Press the power button on the case).The pc did turn on but there was no output to the display,the fans were all running, the hdd and CD drives were not running and when I turned the pc on the motherboard speaker (Which usually makes a bip sound when i turn the pc on)the was no bip sound.Also as you can see in the video in the front io were the led lights are the red is always on while the green is blinking very fast.In conclusion I found out that the power supply is broken.If anyone knows what else could have been broken please respond.
The videos link is here--> https://1drv.ms/v/s!Ak-yh_hDI_zVggPLb_15...
Edit: found out that the psu died and took the motherboard with it.
Это хороший вопрос?
2 Комментариев
Hi @vagelis48076,
What is the make and model number of the motherboard?
What do the red LED and green LED normally mean, Power HDD etc?
из jayeff
@jayeff
My motherboard is a Gigabyte p4 titan series GA8IE800
For the lights I am not sure but I think green is the power and I think it supposed to stay always on , while the red led I think when the hard drive is doing something like opening a program etc. It stars blinking.
из Vagelis
