What is the high ram acer aspire one zg5 support
what is the high ram acer aspire one zg5 support
Это хороший вопрос?
Это хороший вопрос?
Here is a link to the service manual for your computer. On page 22 it states the maximum ram is 2 GB.
Был ли этот ответ полезен?
In practise, ZG5 can only accept 1,5 gigabytes. This is due to following:
So, if you add a memory stick of 256 MB (0,25 GB), 512 MB (0,5GB) or 1 GB you'll be fine as you don't exceed the chipset limitation. 1,5 GB memory sticks don't exist. If you add a stick of 2 GB (or more), you'll exceed the chipset limitation and your ZG5 won't boot.
There are rumors of physically removing the original onboard RAM and then adding a 2 GB stick but I don't personally know anyone having done that. Anyway, I wouldn't recommend it, it would require some skills with soldering iron and such. I also have a vague memory of someone talking about newer ZG5 units having 0 or 1 GB onboard memory, so giving a possibility to reach the 2 GB limit, but I only have met older ZG5's with 512 MB onboard.
So the solution is to through out the al ready memory and put in thew only slot in new 2gb. Isn it?
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 29
За всё время: 17,067
