Why does my screen display only white noise?
I opened my Asus Zenbook laptop the other morning, and the display only shows white noise. I tried all kinds of different keyboard startup combinations, removing the battery etc, but nothing seems to work. The computer only starts up and diplays white noise. When I long press the power button, the fan starts making a loud sound. What could be the problem? Thanks for all the help.
Это хороший вопрос?
2 Комментариев
Hi @jalle656,
Connect an external monitor (TV?) to the laptop's HDMI port and check if there is a display OK on the monitor when you turn on the laptop and it has booted into Windows.
Press the F8 key a few times to toggle between showing the laptop screen only, the external display only or both on together.
If there is no display at all on the external monitor , the laptop may not even be passing POST (Power On Self Test). Are any of the lights on the laptop e.g. Caps light or Power light blinking at all?
из jayeff
I added a second display, and the display recognizes that a device has been added - the external display just is black, nothing is shown on it even though I toggle the F8-key. The Caps light and power light work normally. Thanks for your answer!
из Jaakko Suomalainen
