I forget my password
I forget my mobile password so I rest my mobile how can you help me
Это хороший вопрос?
Это хороший вопрос?
A factory reset should clear all data and restore to factory defaults.
Of course, this is a problem if your data isn't backed up as you will lose it all.
Был ли этот ответ полезен?
Hi @ruggb,
A factory reset will reset the phone but it doesn't clear the password entirely.
If the phone has a Google account tied to it you still need to know the account ID and password to access the phone after a factory reset or know how to bypass the FRP lock (factory reset protection) that has been enabled in the phone by the reset to enable you to setup the phone again after the reset has been done. You only get so far into the setup procedure and no further as it asks for this information
FRP lock is a security feature in Android OS 5.1 and higher versions in case a phone was lost or stolen so that it couldn't be used again or onsold by simply resetting the phone back to its factory default condition as could be done with earlier versions of the OS
If you don't want lose your data you can use any tools for flashing or unlcock by any tool software. There are many tools you can use.
كيف تبديل بطارية
you need to Turn off the phone.
The Phone will continue the master reset, taking several minutes to complete. Once done, you will see your phone is brand new. This method of removing the pin pattern or wiping the data can be done on Phone pattern unlock without pc—no need to connect additional devices.
За последние 24 час(ов): 5
За последние 7 дней: 15
За последние 30 дней: 67
За всё время: 2,607
11 Комментариев
I don't know because I'm noob
из Muhammad Fahim
I forget my phone password
из Rama Mane
My phone was hanging,strucking,heating,full of storage
из Mirza Mustafa Baig
hard reset my phone total reset forgo passwod unlck
из manju manju
how to remove mobile paswarod
=== Update (01/07/24) ===
how to remove mobile passwrod
из oppoA57
Показать 6 больше комментариев
