Repair guides and support information for Lenovo's Z series of laptops.
8вопросов Показать все
What steps must I take to install a ssd on my lenovo z 50-70?
I tried replacing my HDD with a SSD but it shows the lenovo logo and nothing happens. I waited for 10 minute and tried presing f2, f8 and f12, but had no efect. Should I change something în my BIOS setting? I run the latest BIOS version for this model
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
I found this video online: https://youtu.be/kFbJoa9y52s
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I know how to replace my HDD, but I wanted to know if there are some necesary BIOS setting
из
Hi @iulianmaties,
Did you "clone" the new SSD from the old HDD before replacing the HDD i.e. exact replica of the HDD.
Most SSD come with cloning software to make it a seamless uppgrade i.e. clone SSD using software, remove HDD and replace with SSD and turn on the laptop.
It will be like before except faster as you now have an SSD
Is there an OS installed on the SSD?
If there's no Operating System on the SSD the laptop won't boot.
You shouldn't have to change any settings in the BIOS for it to boot if you cloned it.
If you didn't clone it then if you're doing a fresh install you need to boot from an install USB disc and follow the setup procedure.
You need a bootable setup USB disk to do this.
Оценка 0
1 Комментарий:
I will try to find a software ti clone my HDD. I only need the C drive, so it just be a bit more complicated, since I am going to use my HDD externa srorage via usb. So thank, I will just try this
из
Добавьте свой ответ
Iulian Maties будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 41
