@merta63333 let's see the damage to both, the male and female connector. Post some good images with your question. Adding images to an existing question
If you have never soldered on a logic board, this may not be the easiest connector to work on. For a definite workable procedure, check this video I found that the most successful way of doing it for me, is by a process called drag soldering. I prefer to stay away from straight, chisel type tips and hot air, since that can affect the other components around that connector. I use use a Hakko T18-BR02 which has worked well for many of my replacements.
To replace your cable, use this guide MacBook Pro 15" Retina Display Mid 2012 LCD Kabel Replacement
Ultimately, the best way of repairing this, is by doing it the way you are comfortable with. Telling you what tools, technique or consumables I use, does not help you much. Everybody has to develop their own technique of getting it accomplished.
There are many of great people on here, that are capable of doing this repair for you. Remember, it is all up to you, your skills, your tools and your comfort level.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
