Has anyone gotten the Err8 error?
Not having any luck finding other people online with these problems. YouTube is completely unhelpful. Ninja says I need to replace the base which is almost as much as a new air fryer.
Это хороший вопрос?
Это хороший вопрос?
Hi, I just managed to fix my Ninja ol750.
The issue was a severed wire coming from the heat coil to the PCB.
I did not have to put another wire through since it was long enough.
I took most of the machine apart to access all the bits.
Do you still need help?
Был ли этот ответ полезен?
@danielmann31775 hope you took some good pictures. Would be awesome if you can create a quick and dirty guide for that. Lot's of Ninja questions could be resolved by that. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Wow this is great! I'm going to use your information and try to fix mine
@danielmann31775 Awesome. It'll really help people out!
@anniehughes while you work on yours take some good pictures as well and maybe we can all put those together and create a guide for the community.
@danielmann31775 how did you remove the top plastic cover on the hinge? As this seems to be the only bit I need to remove to get access to the rest of the lid, I think my thermal fuse has gone, as no fan working.
There are 2 parts to the lid.
One is the top hat which is held in by clips/tabs.
The other one is held in by a couple of screws. One of them is within the tab that you use to slide to select the different cooking options.
You need to remove the top lid first. I broke one of the tabs because I didn’t know better. Look at the pictures carefully to remove it without breaking. There are 2 screws under the top hat to completely remove the lid cover.
@anniehughes "err8" should be a blown thermal fuse. should be on the inside of the lid. Looks to me like you are needing to get ready to take your Foodi apart. There is always the possibility of a bad heating coil or a bad fan. You did not tell us if your Foodi just gave up quietly or if anything preceded this.
Since there is not a lot of information about it out, you are venturing in unexplored territory. Take lots of pictures and post those on here if you are encountering problems.
Adding images to an existing question
While you work on your Foodi , take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
This just happened one day when turning it on. Nothing preceded this. Foodi worked normally the day prior. I will try inside the lid first.
I just encountered the same problem this week with mine. It was working fine prior, I was in the middle of air frying and it just stopped and gave that message. We’re you able to fix it?
Daniel’s answers have been really helpful, but despite removing the top hat and every screw in sight, I am reluctant to try levering the lid cover off, and it won’t lift gracefully.
I’m trying to get to the slider sensor. The hinge side plastic cover looks like it might need removing separately, as your photo shows two ‘finger nail’ shaped cut-outs that are plainly covered in normal circumstances, but it’s not budging. Also you have removed the vent pin, but I don’t see how.
Here’s my progress so far. Any hints would make me v. happy. Thanks in advance (to Daniel and the rest of the community).
Steam vent assembly & pin now out - knurled retainer needed unscrewing. Lid cover still stubborn.
За последние 24часов: 37
За последние 7 дней: 226
За последние 30 дней: 1,041
За всё время: 5,435
