Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433вопросов Показать все
Help with RAM upgrade?
I need to upgrade the RAM in my iMac. It is either an EMC 2134 or 2211, but I don't know which. I need help figuring it out. here are my system specs:
2.8GHz Intel Core 2 Duo
2 (1GBx2) GB 800 MHz DDR2 SDRAM
L2 Cache: 6MB
Bus: 1.07GHz
SMC Version 1.30f1
OPTIARC DVD RW AD-5630A
ATI Raedon HD 2600 Pro 256MB
WDC WD3200AAJS-40VWA1 320GB
I am currently running snow leopard with no problems. Again, can anyone figure out whether this is a EMC 2134 or 2211? Thanks.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
in Apple parlance, your iMac 2.8GHz Core 2 Duo with 1066MHz system bus would be AKA an iMac 24" (Early 2008) model
this iMac has 2 memory slots and according to Mactracker it can support up to 6GB of RAM, 200pin PC2-6400 (800MHz) DDR2 SO-DIMM (support for up to 6GB in this model is confirmed by other sources, even though Apple's official spec is 4GB)
note: the iMac 24" (Mid 2007) model has a slower system bus 800MHz, has only 4MB L2 cache, and only supports up to 4GB of PC2-5300 DDR2 RAM). So it seems your iMac is the Early 2008 variant I mentioned earlier.
BTW, you should be able to find the EMC number on the bottom of the stand of your iMac
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Mark будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 4,562
