The XIAOMI Mi L32M6-EI TV, also known as the Mi TV 4A Horizon Edition (32-inch), is a HD Ready (1366 x 768) Smart Android LED TV launched in 2020. It runs on Android TV with built-in Chromecast and Google Assistant.
My TV Does not Start
Hey Team,
My MI 4A TV is neither starting from the remote nor from the power button of the TV. The red light always keeps on burning in the TV, which used to turn off after starting the TV, but now it does not turn off.
Это хороший вопрос?
Счет 2
5 Комментариев:
Foxsky led tv 32 inch pawer on problem
из
No my tv was after starting it white screen coming
из
My tv does not start
из
Tv not open
Read light show but tv not on
из
@henockberhane are you looking for something?
из
Добавить комментарий
2 Ответов
@devsharma59131 that is a little known TV and of course schematics etc. are not available. WE would need to see your boards. Remove the back cover from your TV and take a look at all the boards. Check for obviously damaged components. Like blackened,charred or missing components. Post some good pictures of each board as well as one of the complete layout, so we can see what you see.
Since the red power LED light is on, that would mean your power board supplies the standby voltage. It could be an issue with the main board not "telling" the power board to turn on. For that you would have to measure the voltages on the connector from the power board to the main board cable.
Adding images to an existing question
Был ли этот ответ полезен?
Счет 0
Any TV with a remote has the internal remote control circuit powered all the time (red LED indicator on). When triggered, it closes a relay or solid state switch that is usually on the power board (red LED off). The power switch will trigger that as well as a signal from the remote. Therefore the likely cause would be the power board, but may be the remote receiver which is normally separate.
At any rate, it requires opening up the TV and making some tests. But, without service info it will amount to parts jockeying to find the right part - and it may be just a bad connection.
Счет 0
Добавьте свой ответ
Dev Sharma буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 13
За последние 30 дней: 49
За всё время: 996
