My phone is lagging
When I start the phone the it start lagging
Это хороший вопрос?
Hi @realmec11
Start the phone in safe mode and check performance.
If it is OK i.e. no lagging, then a downloaded app may be the cause of the problem. The trick is to find out which one is the culprit.
You will need to uninstall each downloaded app one by one and test the phone in normal mode between each uninstall. When it works OK in normal mode, the last downloaded app that you uninstalled was the cause of the problem.
A downloaded app is one that you downloaded and installed and wasn't pre-installed on the phone already.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 44
За всё время: 343
5 Комментариев
No sometimes lagging
из Najilnavas2
Yes i have this problem every day
из Shyam
Auto switch off mobile app not open
из Realms c12
из Ram Nishad
laggings realme c11 phone
из Realme c11
