Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Didnt unplug the battery connector while changing the display
I need help, my ipad display isnt working. I have an ipad mini 2, the display (not the digitizer) was partially destoryed with black pixels due to force but it was still working, its really roughly used and repaired. I only changed its digitizers a couple of times. Luckily, i already have another ipad mini 2 lying around which is completely destroyed but its LCD display is completely fine, so i opened the ipad and simply disconnected the LCD connector (its not broken) and i installed the other LCD from the other ipad. I powered it on, but i couldnt see any display, just a black screen. I tried to put the old LCD back, same results, no display. I then read an ifixit guide and it asked to disconnect the battery connector first before disconnecting the lcd connector. I didnt remove the battery on the ipad, should i remove it? Also its a really old ipad so apple doesnt repair them and i dont want to repair it because i have the parts.
I also cant power the ipad off, i put it away hoping the it would lose charge after a day or more.
Can i unplug the battery anyways and put the display back on hoping its backlight fuse isnt blown??
Also, i have changed the digitizer many times without disconnecting the battery and it was fine.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Try to find diode readings for the fpc connector the lcd is connecting too.
Meter in diode mode and put red on ground and black on fpc connector. Careful not to damage pins. Sometimes their is OL on the diode readings and you can have a missing filter on one of those lines and not know it. If you don't find anything wrong in the diode reading. Inspect and trace back any OL pins and look for missing components
If that is all ok, you might want another testing working lcd to test with. A completely dead battery can cause no display as well, putting device into dfu mode and leaving plugged in to a computer overnight can help charge battery
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Rahmkar буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 89
