Repair guides and disassembly information for Apple's 7th generation iPad. Released September 25, 2019. Model numbers: A2197, A2200, and A2198.
doesn't turn on.
it was about a year ago when it stopped charging with its original charger, i then tried mac's charger to charge it. but it also didn't work, it was charging but very slowly and suddenly went dead since then.
i send it to local repair shop and they said probably it is motherboard issue and can't be solved. can you suggest me what to do?!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
I know it's a fairly common issue for the CPU to die on the 7 series and it's just not worth fixing.
You could reach out to a board repair specialist to see what they have to say. If you're out of the US, I believe iPad Rehab might be able to accept the repair. If you're in the US, both iPad Rehab and VCC Board Repairs could take a look at it. I've personally taken Rehab's board repair course and I send my data recovery jobs to Jesse at VCC. Good luck!
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Omor Seebtaien буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 84
