Battery Too Low To Charge! 1 Year Old Battery! Fine Yesterday!
Why would my battery charger indicate the voltage is too low to charge while the battery is in the car, but when I take the battery out, it charges fine on the same battery charger without showing any faults?
Это хороший вопрос?
1 Комментарий
The battery was purchased December 2022 and is a sealed battery. It was purchased from Walmart. After charging for several hours, I checked it with a volt meter and it simply would not hold a charge. I returned it and Walmart exchanged it without incident. Once the new batter was in, I used my volt meter to check the alternator and it was charging appropriately. This excluded the alternator as a culprit. The batter was in a 2017 Kia Sedona. New battery, everything seems to be working fine....so far. But thank you for your answer.
из Pappy
