A power bank is an external battery for your device when you are unable to charge and need to charge a device.
My power bank is unable to charge and to be charged
My power bank suddenly stop charging and it is also unable to charge any of my device. What should I do to repair it please? It's an oriamo power bank
Это хороший вопрос?
Счет 4
Добавить комментарий
1 ответ
@law23805 attach an ammeter to it and see if your power bank still pulls a charge. If it does not check the charge connector and make sure there are no bend/broken pins, no corrosion and no debris in it. You can clean it will a few drops of isopropyl alcohol and a few puffs of air-in-a-can. If that does not resolve it, time to open it up and take a look at the charge controller board etc. and post some good pictures of what you find. Everything will be a guess until we see what is going on with it,
Adding images to an existing question
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Law буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 24
За всё время: 330
