CD door clip switch will not remain in contact
Hi, The CD drive door on my model 1 Saturn has a 'tower' type door switch. The plastic tray lid presses a micro-switch against a contact plate when the lid is in the closed position. This is no longer happening. I have tried taping the micro swith and contact plate together, this works for a little while until the microswitch eventually moves off the contact plate and the door reads as open again, particularly annoying when you are in the middle of a playing session. Any methods for the best way to repair this? Can the switch be bypassed altogether? thank
Это хороший вопрос?
Счет 0
1 Комментарий:
@atlasdelta post some pictures of what you got going on there. I am sure you could bypass the switch.....we just need to see your setup.
Adding images to an existing question
из
Добавить комментарий
