Is Apple Watch SE replacement display compatible with Apple Watch SE 2
I have an Apple Watch SE 2 40mm and the display was damaged during an accidental drop. The display cracked around the perimeter and has popped out (leaving shards still adhered to the body).
I found the in-depth guide for replacing a damaged display for the Apple Watch SE, but nothing for the SE 2. It seems like removing the display is essentially the same process, but before I purchase the replacement part from ifixit I am curious if the display for sale on this website (Apple Watch SE 40mm) would be compatible with my SE 2? Does ifixit sell a replacement display specifically for the SE 2?
Это хороший вопрос?
2 Комментариев
I think the LCD panel and the digitizer is the same between SE/5 and SE2, because the flex cable seems to be the same. The only thing I don’t know is the nfc circuit and the glass shape
из Dan
I can confirm, after successful swap, that LCD and digitizer from SE/5 is fully compatibile with SE2022 (in my case taken from Watch 5). I only swapped the NFC from original screen to the new one.
из Dan
