Xiaomi 11t pro. Battery stuck at 15%
Hello, I have a problem with my Xiaomi 11T Pro. The phone froze at 15% battery charge. Neither a software update or a battery replacement helped. What could this be?
Это хороший вопрос?
Это хороший вопрос?
If the new battery didn't solve the problem, most likely the problem is at power management ic on motherboard. Also common issue of false battery percentage is a bad connector.
Был ли этот ответ полезен?
I also have the same issue, my xiaomi 11t pro didnt increasing, but the overall performance of the phone is okay and smooth, just the battery concern stuck in 15%, i think the battery is need to replace a new one...
За последние 24часов: 4
За последние 7 дней: 57
За последние 30 дней: 281
За всё время: 2,328
@oldturkey03 The phone works well, it charges correctly, but it always shows 15% battery charge, no matter if I discharge it or charge it. I also replaced the battery connectors, but it didn't help.
из Gustek
It's a hardware problem, I fixed it opening the phone and pressing the battery connectors
из ssss
@ssss17468 this is the best answer, i already solved my problem
из Romano Raul Romulo
