The Mitsubishi MMCS NR-242 Series with SD is a car navigation system produced by Mitsubishi Motors that includes an SD card slot for expanded storage capacity. It was succeeded in 2017 by the Mitsubishi Smartphone Link Display Audio (SDA).
Replacing MMCS E-12 with W-12
Hi, I hope you can help.
My E-12 unit has a broken digitizer (screen is fine).
I found a W-12 replacement, whole unit relatively cheap.
Would it work on my 2015 Mk3 Outlander Gx5hs without coding and cable swap?
Thanks.
Это хороший вопрос?
Счет 2
1 Комментарий
Hi, did this swap from E-12 - W-12 work for you?
Thanks
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
https://pinoutguide.com/Car-Stereo-Mitsu...
If this website is to be trusted, the pinout should be the same. I would say it's at least worth a try.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Thanks a lot. In you experience, do those units require a pin code or to be ECU registered, if came from another car?
из
Добавьте свой ответ
Toporo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 16
За всё время: 684
