SNES won’t power on
I’ve changed the Pico fuse, the power supply and barrel jack work, and so does the switch… I turn it on and I get no light… any ideas?
Это хороший вопрос?
Оценка
0
За последние 24 час(ов): 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 136
@aaronjosep48927 Do you have a multimeter?
из Andrew S
@andrewsawesome ya I checked pretty much everything
из Aaron Josephson
@aaronjosep48927 Did you check to make sure that the voltage regulator is working properly?
из Andrew S
@andrewsawesome I actually did not where is that located and how do I check it?
из Aaron Josephson
@aaronjosep48927 Turn your multimeter to the 20 VDC range (if you need help with this, upload a picture [ Adding images to an existing question ] of your multimeter and reply to this comment). Plug your power brick into the wall, then into your SNES. Find a component labeled "U12" or "IC12" on the motherboard. Touch the black probe to the middle pin and touch the red probe to either side. You should have about 10-18 volts on one side and 5 volts on the other. Let me know what voltages you get.
из Andrew S
Показать 6 больше комментариев
