Is anybody knows what is the IC controlling the toothbrush?
I have two toothbrushes Oral-B D100 (type 3710) for kids with the same problem : They're dead ! I opened them and confirmed the voltage (1.2Vdc). The power button did nothing. The problem seems to come from the 14 pins IC inside. It it a CCE7102 chip, but there is no information on Internet about this IC.
Is anybody can tell me what is the purpose of this chip (probably a PIC or something like that) and how to confirm if the problem really come from this one ?
The battery is good, the motor works (as soon as I put 1.3Vdc on the motor, the head start to wiggle. If I bypass a transistor controlled by this IC just beside it (shorting emitter and collector), the toothbrush start normally (until I remove my short).
I know it is just a toothbrush, but I'm really curious about the fonction of this IC an I want to learn. Thank you
Это хороший вопрос?
@royde Can you upload a picture of the IC? Adding images to an existing question
из Andrew S
There it is. Thank you
из Royde
