Identified by model number: JBLLIVE660NC. It is a wireless over ear headphone that was released in 2021. The JBL Live 660NC is a Bluetooth 5.0 capable headphone featuring Adaptive Noise Cancelling technology, JBL Signature Sound, and up to 50 hours of battery life.
The right ear started cutting out, is it fixable?
The sound in the right ear started to cut out, it would work only in a certain position. It's pretty much complete cut out now, but i do really like this headphones and would much rather fix it!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@madssaucexx since there is no good teardown yet, take a look at this video to work on your headphones. You will have to modify it to suit your need. Then check your wires from the circuit boards to the drivers (speaker). You may have a broken wire or a bad solder issue. If you get it apart, and you can see the wires, post some pictures of what you got going on with it. That way we can see what you do. Adding images to an existing question
While you work on your headphones, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Mads Saucexx буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 31
За всё время: 1,222
