Not all the bulbs light up
I have 423 addressable LEDS that I soldered (first time) together. I turned it on and everything worked. I then put the strip into the location I wanted and now only the first 50sih work. I have looked at all my solder location and everything seems fine. I do have a multimeter to help figure out where my problem is, but I don't know which function/how to use it. Any help will be amazing.
Это хороший вопрос?
Счет 0
2 Комментариев
@mitchellb75424 How are you powering the LEDs? If using an external power supply/LED Driver, what are its specifications?
из
The LEDS are powered via external source, 5V 2A. I know that since I had to re-solder some wires, I am sure that is the issue but as I don't know which ones are bad, I was hoping there was a way to test via multimeter.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@mitchellb75424 The first thing I would do would be to check the voltage on the first LED. You can do this by putting the multimeter probes in the common socket (black probe) and V etc. socket (red probe). Set your multimeter to 20 VDC (V with a straight solid line and a straight dotted line) or just VDC (for an auto-ranging meter). Plug in the light strip and measure across the two solder points of the first LED that doesn't light up. What voltage do you get?
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
I got 4.89 on the furthest strip.
из
@mitchellb75424 Can you upload a picture of the LED strip? Adding images to an existing question
из
Добавьте свой ответ
Mitchell B буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 231
