ssd usage pinned at 100 percent with 0.1Mbps/sec
ok let me start from beggining. before upgrading to a ssd i had no problems at all, then i upgraded to m.2 sata 3 ssd ( kingstone brand ) and the problem started. when booting up ( doesn't matter if plugged in or not ) there is a random chance that it does not boot up ( goes to a weird gray screen ) and after multiple hard resets it boots up to windows and there is the second problem, there is chance that pc is not responsive and after trying so hard to open task manager it says disk 100% 0.1Mbps/sec . i have tried multiple windows installs with forcefully not installing new drivers, still the same issue. when it works it works fine.
Update (11/11/23)
this is the closest photo i have found about the ssd and this a 120G one mine is 256 and
this is my ssd ( i cant remove the sticker its warranty ) i could not find any information on its speed sadly
Это хороший вопрос?
@siaabd what exact model is your Kingston SSD?
из oldturkey03
@oldturkey03 - Kingston SMSM151S3/256G
из Dan
