How do I dislodge a cd from the player?
I have a cd stuck in my Bose CD player. The eject button on the remote will not dislodge it. I'd read, on U-Tube no less, a few years ago that shaking the player would work Didn't and seemed a rough solution.
Это хороший вопрос?
I have this problem too. The CD will not eject. Any ideas how to get it to come out?
из Kathica
If the Drive is one with a tray. there will be a small hole on the face of the tray, usually on one side. Take a paper clip, bend it open and push it into the hole, like you would do to open the SIM tray on your phone.That should open the tray. If no tray, see my other answer.
из bill
My Bose will not take a disk in. Like the motor is dead. You hear a slight noise when the disk separates the sensor which would normally activate the motor to take the disk in. I took apart and manually inserted disk. It read and played the cd no problem. I hit eject but it wouldnt eject. Flashed ejecting on screen and then Said disk error when it wouldnt eject. If I hit eject again it would spin the disk up and play again. I replaced the motor but it did not fix anything. I have recapped the board. No change. Very frustrating.
из Brian Arnold
